Jon,
Fitting a new leisure battery will have absoutely no affect on the fridge when you are towing.
1 , have you changed tow car recently? if you have check that the 12s socket wiring is correct to the age of your van, remember they are wired differently for pre & post 1998 caravans.
2. if you have not, then check the van & cars plugs & sockets, make sure that the pins are clean & bright, check also for any signs of overheating of either the plug or the socket, if there are, change both of them.
3. check that there is power to the fridge when the engine is running, see below
From the Caravan Club's Towbar wiring information
12N & 12S Sockets To Suit October 1979 to 31 August 1998 Caravans
TERMINAL COLOUR 12N SOCKET 12S SOCKET
1 Yellow L H Indicator Reversing Light(s)
2 Blue Fog Light(s) Caravan Battery Charging
(Ignition Controlled Supply)
3 White Return (Earth) Return (Earth)
4 Green R H Indicator Interior Lights Etc (Permanent Supply)
5 Brown R H Tail Light Sensing Device
6 Red Stop Lights Fridge (Ignition Controlled Supply)
7 Black L H Tail Light
& Number Plate Not Used
Notes
The supplies to 12S pins 2 and 6 must be installed such that they are live only when the vehicle engine is running (see Sections 3.5.13 and 3.5.15 below).
The supply to 12S pin 2 for caravan battery charging has been customary practice in the UK for many years. However, it has never been adopted into a British or other standard for towbar wiring. It is, therefore, frequently ignored by vehicle manufacturers in their wiring kits.
See section 3.5.16 for advice regarding 12S pin 2 if towing a continental-built caravan.
With the exception of the 12S pin 2 connection as mentioned above, sockets wired according to these specifications will comply with British Standard BS AU 149a (12N) and BS AU 177a (12S). These standards are effectively identical to International Standards ISO 1724 (12N) and ISO 3732 (12S).
3.3 1 September 1998 And Newer Caravans
These are built to European standards, one of which defines the 12V wiring, and results in changes to the 1 2S system. (The 1 2N system remains the same.) An extra earth acts to separate the fridge power supply from other circuits, minimising the risk of overloading the return wire when several circuits are used together. Battery charging is now officially included, but via pin 4, not pin 2, as was usual practice in the UK before, but never included in previous standards. Pin 4 also operates interior lights etc, but not at the same time as battery charging. Switching to achieve this is done in the caravan.
12N & 12S Sockets To Suit 1 September 1998 And Newer Caravans
2 Blue Fog Light(s) Sensing Device
3 White Return (Earth) Return (Earth) For Pin 4
4 Green R H Indicator Interior Lights etc or Caravan Battery
Charging (Permanent Supply)
5 Brown R H Tail Light Not Used
& Number Plate Return (Earth) For Pin 6
Notes
The supply to 12S pin 6 should be live only when the vehicle engine is running (see Section 3.5.15 below).
12S pins 3 and 7 should not be joined together at the socket. They should be taken separately to an earth point on the vehicle structure. Failure to do may increase the likelihood of overheating of the 12S plug and socket, especially if damage to pin 7 occurs (see section 3.5.17).
12S pin 4 must be permanently live for both battery charging and interior light etc functions to operate. The fridge circuit must work correctly for switching of the pin 4 supply between these functions to occur.
At the time of writing, the standards for vehicle wiring have not been updated to match the latest caravan wiring standard. The above specification complies with British Standard BS AU 149a (12N) and the effectively identical International Standard ISO 1724. BS AU 177a and ISO 3732 (12S) do not yet include the earth via pin 7, and hence this connection may be omitted by some makers and installers.
4. if all is in order & you still don't have power when the engine is running, then the VSR (volatge Sensitive Relay) that trigger & then supplies power has failed & needs to be replaced
