Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
We’re currently investigating an issue related to the forum theme and styling that is impacting page layout and visual formatting. The problem has been identified, and we are actively working on a resolution. There is no impact to user data or functionality, this is strictly a front-end display issue. We’ll post an update once the fix has been deployed. Thanks for your patience while we get this sorted.
Hi, once again this is very simple no dought but we are new to all this... we have a 1991 sprite musketeer,will the fridge run of gas, electric or both... Please help any advice will be greatly appreachated... Thanks Jo. x
If you know the model number it would help, it starts RM****
However, it will certainly run off gas, as long as it is in working order.
If it has electric capability as well, there should be a switch (normally with a green indicator light) for mains operation.
Your fridge will work on all 3 power sources (as long as both the 12v and 230v heating elements are OK)
There is not a green light switch, just a grey voltage selector switch and a red 12v selector.
The 12v will only work when connected to the car with the 12S (Grey) plug and the engine running
