We have a Sterling Europa 495 2004 and the fridge is small compared to the latest 'vans. Can a newer fridge be retro-fitted?
Hello Roger,John - your comment about needing a competent person working to the regulations applies to domestic properties but not caravans - I think it's one of the most stupid exceptions to sensible safety regulations particularly given the poor quality of some caravan workshops.
Don't ask me I'm as baffled as you and Christine. JTS.So can Christine get a bigger fridge or not?
anyone carrying out worrk on gas appliances in a home does not need to be a registered fitter eitherHello Roger,
You are partly correct. The Gas Regulations do differentiate between touring caravans, and other installations in so far that the person undertaking the work on a touring caravan does not have to be a 'registered' fitter, but that does not allow them to ignore other relevant legislation.
Health & Safety legislation is superior to the Gas Regulations. Technically this does apply to DIY as well as organisations. H&S make it a requirement on the responsible person for a gas system to ensure that only persons who are competent to do so, are allowed to work on the system.
Where the Gas regulations do allow a 'non-registered' fitter to work on a touring caravan, the work must still comply with H&S and all relevant standards, and that includes the need for testing. If the correct procedures for all aspects of the work are not completed correctly, then the fitter has failed to demonstrate competency.
To be compliant the fitter must therefore be 'competent' and 'able' to complete all aspects of the work in accordance with the regulations. It is conceivable that a non registered fitter may have the necessary skills, knowledge and equipment to comply.
It is therefore much easier to simply point out that a 'competent' person must do the work on touring caravans.
