Front towing cover not fit for purpose!
Aug 4, 2004
4,343
On 10th May we ordered a front towing cover from a company, not Protec, for a 2011 Lunar Delta TI caravan. It cost £99 and we paid using a pre pay Mastercard. Cover was delivered on 7th June.
We then try to fit it onto the front of our caravan, but found that the rail across the front of the caravan protruded outwards for about two centimetres on either side. When the cover was fitted, you could see that the material was stretched on the points of this rail on both sides. We felt that after use, the rail would eventually wear through the cover. On contacting the supplier, they told us to put something over the end pieces to prevent premature wear. I asked them why they had not supplied' the something' and was told it was my problem. We also noticed that the cover covered up the front lights on the caravan. Although they are visible through the cover in the dark, they are not very visible during the daylight in heavy rain. The supplier persuaded us it was okay and that we should try it out.
A day later we went on holiday
and on towing we noticed the bottom front corners worked loose and started flapping in the wind thus accelerating wear. On our return two weeks later the same thing happened despite us following the instructions to the letter. Last weekend when we were away, we met up with another person who had the same caravan and the same cover. He had exactly the same problem as us. Bottom corners of cover comes loose within first 10 miles! We then emailed the company about the cover giving them the opportunity to either modify, repair or refund, but they never responded. This was last Thursday.
If you look at their website you are unable to get a 2011 Delta TI off the drop down list. In their returns policy they state no return due to it being a special order yet their website in numerous places states "Universal front towing cover" which is not exactly custom made. Where do we stand with a return of the cover?
We are thinking of utilising the Distance Selling Regulations as we notified them of the issue verbally within two days of receipt of the cover, but at that point they persuaded us to keep it. Secondly we may consider doing a chargeback and if so how long do you have to wait before you can do this?
We are very disappointed with this company and lack of response from customer services. In all honesty at present we cannot recommend them to any one.
4,449
You have described the product as having been purchased for a specific model of caravan. If it fails to provide the function that a reasonable person would expect from its description and sales information, then the product is as your headline states - not fit for purpose. That is clear breach of SoGA.
By declining to accept the product back under these circumstances they are failing in their responsibilities both under SoGA and Distance selling regs.
5,501
Sir Stagger
Not acceptable.
The National newspapers, Which mag etc all have help columns that take up these problems.
Tongue in cheek, I ask why PCv can't offer a bit of muscle to help you???
Aug 4, 2004
4,343
I assume as above however they are not responding to emails even though they have acknowledeg receipt. I guess the next thing is regsitered mail to create the paper trail. They were made aware of the make and type of caravan. On their website under front towing covers they state "Any make & model with 2 awning channels up to 2.3 metres wide."
I spoke to them on the phone and gave them full details therefore they should have known that the rail on the front of the Delta TI is almost 2.6 metres wide as the overhand on either side is about 1.5cm. They state that they have an extensive database.
Their returns policy states;
Returns Policy
Unfortunately, the nature of our product means we cannot offer our customers a returns policy. In addition, if your cover has already been put into production, you may not cancel your order. If however, in the unlikely event that your cover is faulty, we will arrange for your cover to be collected and repaired, altered or replaced. If you have a query regarding your cover, you can contact our sales team on xxxxx or info@xxxxxx.co.uk
As it is clearly stated it is a universal product that implies it is not custom made. In essence they are in breach of SOGA and Unfair Terms in Consumer Contracts. By now most of you should have a good idea of the supplier which is not a dealership.
