Front windows coming apart
Nov 29, 2019
Hello my first visit to this forum and I have a problem with two of my front windows they are coming apart ie splitting, is there any sealant that you can use that does not look terrible after the repair :( thanks Cath
Sep 5, 2016
928
119
4,935
Its not a sealant you use but there sre several bonding agents out there do a search for them, also I had this problem several years ago and took the window to a cpmpany in Bradford that do a professioal bonding job,
937
Repairing a caravan window is a tricky business as the acrylic is now aged and brittle, so great care must be taken when trying it.
A number of people have had some success with Bondrite , but again, great care in application is required and careful preparation is essential.
This is made even more difficult as the top of he window is held by a pressed on hinge bar, so the two panes are not entirely separate.
The company called EECO will effect a rebonding repair but the window needs to be sent to them (they collect and deliver), but only if there has not been a previous repair attempt.
https://eeco-ltd.co.uk/
May be worth a phone call to them.
Jun 2, 2017
118
29
10,585
Hi
Depending what age your caravan is and the window manufacturer but if they were made by Polyplastic and they were a certain batch you can get them repaired FoC or replaced at a discount. There was a known fault of the windows separating on the seals
My previous van was on the fault list & I had them re-sealed free.
If you go onto the Polyplastic site it has or did have the faulty years & models so may be worth a try before you DIY.
If yours are on the list you have to take the van to one of their nominated repairers for the Repair/Replacement
Mike
