Hello Alan,
Often people have a much exaggerated expectation of what Air Con can do in a caravan.
The proper installation can make a big difference, but you must also be aware of the actual capacity of these units.
Whilst I have seen some of the Frostair units, I do not know specifically the the cooling power of the 1700, but I will assume the number relates to the cooling power in Watts. Lets put this into perspective:-
Most AC units in cars are rated at about 5kW and the passenger space is about 4 cubic Metres That gives about 1.25kW per m3.
The Frostair unit is 1.7kW and the volume of a two berth caravan is typically about 15m3 that gives about 0.113kW per m3 or about one tenth the cooling capacity by volume.
There are other factors which will improve on that a bit mainly due to the level of wall and roof insulation, but against it is the surface area.
Let us be generous and and say its about 0.25 the power compared to a car.
It just isn't going to cool the whole caravan down in the same way that an AC system in a car does.
what you have to do is to decide where you want the cool air, and direct the outlets to that area.
I found that arranging ducts to blow cool air at high level to the main seating area provided a cool movement of air when seated. This was the best we could do with the limited power available to run the AC.
You raise the question of whether the unit needs to be re-gassed, Only an refrigeration engineer could give you a definitive answer to that, but if it has lost its gas, it needs to be checked for leaks.
The Frostair is probably only 1.7kW.
The passenger space in a car is typically in the region of about 4 cubic metres, where as the volume of a caravan is about 12m3.
