fuel cost with towbar fitted
Jul 25, 2008
18
How much difference to cost of deisel when car has been fitted with a towbar.Does it make a big difference after towbar has been fitted?
Jul 25, 2008
18
sorry if that doesnt make sense...what I mean is....after fitting a towbar will I use more deisel (just driving without caravan)
Jul 18, 2006
303
I assume you query is regarding aerodynamics (ie drag) ?
If so Daniel is right, as the towbar is out of any "wake" of airflow as it is too low.
It would be different if you had a roofrack or roofbox though.
Jul 31, 2006
417
Actually Linda you will use slightly more fuel with the tow bar fitted, aerodynamics aside, you've increased the unladen (kerbside) weight of the car by the weight of the tow bar.
But don't worry the increase in fuel consumption will be so miniscule that under normall driving conditions you'll not notice any difference at all!
Jun 1, 2008
98
Not wanting to sound aggresive or argumentative but are you serious?
Try washing the car more often to make it more aerodynamic as all the dirt particles will result in more drag
3,231
Any additional weight in, or on, a vehicle will increase it's fuel consumption. A towbar will make a slight difference but less than the effect of an extra passenger.
A difference, yes, but not enough to measure outside a laboratory.
