J joner818 Feb 12, 2008 79 0 0 Apr 8, 2010 #1 can you tell me if you light the grill should you have to blow on ti make the flames go all the way across, or does it need cleaning if so is it an easy job for a diyer
ProfJohnL Mar 14, 2005 19,017 4,245 50,935 Apr 8, 2010 #2 For your safety, only a competent person should undertake work on gas appliances. If you are not familiar with regulations and the necessary equipment you do not have the necessary competencies to undertake gas work.
J joner818 Feb 12, 2008 79 0 0 Apr 9, 2010 #3 For your safety, only a competent person should undertake work on gas appliances. If you are not familiar with regulations and the necessary equipment you do not have the necessary competencies to undertake gas work. Click to expand... ok thanks have to book it in
