Hi all just had a leaflet through the door for caratec caravan servicing has anyone used them or heard of them? as I might try somewhere different for my servicing.
Should still be under warranty as it was purchased in 2010 i'm going to take it to my regular dealer as they valet it for me aswell included in my service.Damian-Moderator said:Quote " Gassafe - Every contractor or sub contractor employed to work on gas systems must be registered with Gasafe and ticketd for the systems they work on. ACOPS Gas Certified is not the same thing."
I must strongly disagree with John L on this point.
First and foremost, privately owned caravans are exempt from Gas Safe regulation.
Secondly, any caravan engineer working on a customers van MUST be at the minimum ACoPS qualified, which is all that is required.
Being ACoPS qualified ensures they will adhere to GSIUR's, Health and Safety and be "competent" to work on caravan gas systems.
The situation is different for vans hired out as part of a business, there the gas operative MUST be Gas Safe Registered.
If your van is still under warranty, Caratec are NOT an Approved Workshop so they cannot mainain your warranty.
Yes because if there is any parts that I require I get them direct from the dealer the price is acceptable but it is a bit steep but they do an excellent service.Damian-Moderator said:Quote " Should still be under warranty as it was purchased in 2010 "]
Whilst under warranty any NCC Approved Workshop can undertake the servicing, but as you seem to get everything from your Dealer, at presumably an acceptable price you are sensible to stick with them.
hi John, I strongly disagree, if there is an exemption it is there for a reason. mainly for changing bottles and regulators. while it is true that most owners would not undertake major gas refittments, modifications or servicing, the need for owners to do certain things with gas is still there, for example if you change to propane during the winter, or the site does not have the right bottle, the pipe regulator ect, would also have to be changed, if the exemption was removed all gas work would have to be done via a gas safe mobile fitter on site, there is no middle ground,Prof John L said:Hello Damian,
This just shows how silly the private caravan exemtion is, and its about time it was reviewed.
Gas Safe DOES have a category approval for LPG - Touring Caravan.Damian-Moderator said:Gas Safe have no input or influence over touring caravans, only GSIURs and H&S
