Being a novice on rallies - will i still get hot water for a shower if im running off just battery power and gas?
i have a 2005 eccles sterling if that helps?
thanks
carl
thanks
carl
hi Damien thanks for that -Yes you will still be able to shower using gas to heat the water and 12v for the pump
thx damianCarl I am pretty sure you have the Ultrastore water heater in your van.
It will heat water using either gas or electric (230v), or a combination of both for quickk heat up (but NOT to be used together for long periods of time)
You have to make the choice of gas or electric, if on a mains EHU, then using electric is sensible.
To use gas, make sure the outer flue cover is off and use the control inside the van to start the heater (havig made sure the gas is on and isolation tap is in the open position).
It is always very important to ensure the heater is full of water BEFORE using either heat source, more critical regarding the use of the electric heater, or you can do expensive damage to the heater.
thanks again damian - really appreciate it -Carl, to fill the hot water system make sure the yellow drain valve (next to the Ultrastore) is shut,
Fill the aquaroll, plug in the pump (if it is anexternal one)or switch the pump on(if it is an internal one), open the sink HOT tap and let run until no more air comes out.
Then open the bathroom HOt tap, until no more air comes out, then do the COLD taps.
Only then do you start the water heater, on gas or electric.
The gas control is marked Ultrastore (or should be) and has a selector for Off or ON and a temperature selector dial.
On electric there is no temperature control, it automatically heats up to 70 degrees.
If you want someone to run through all the equipment on the van with you, I suggest you contact the nearest mobile mechanic
http://www.mobilecaravanengineers.co.uk/mcea-find-an-engineer.htm
and find one nearest you.
