Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
We’re currently investigating an issue related to the forum theme and styling that is impacting page layout and visual formatting. The problem has been identified, and we are actively working on a resolution. There is no impact to user data or functionality, this is strictly a front-end display issue. We’ll post an update once the fix has been deployed. Thanks for your patience while we get this sorted.
I have just returned to caravan this evening and tried to heat the water on gas. Normally I just turn the dial down and it clicks and the green light comes on. 15 mins later ... Hot water. However tonight turned the dial downwards as normal and no light or click. Any advice
From what you have said so far it seems that you have a failure of the PCB that controls the gas side of the water heater.
Unless you know exactly what you are doing, it is time to get a mobile engineer in to sort it out.
