hello all
Jun 7, 2013
hi to you all
we have just acquired a cristall moorea 450tf as first time caravanners and we like it a lot......we worked out how to use it all the only problem we had was that we could not work our how the waste water system operates so if anyone can help it would be appreciated thankyou
4,392
Welcome to the Forum Anthony,
I suspect your waste outlets are pretty similar to all other caravans, either two or three outlets ; to which you attach waste pipes which in turn you feed into your wastemaster or similar waste water collection tank for regular disposal at the "grey " water drain.
You can make up your own pipe work or buy waste pipe joints ready made up linking the outlet together and then into one pipe into the waste tank.
Some sites have fully serviced pitches enabling you to run waste pipes directly into a drain negating the need to use your own tank.
1,722
Hi anthony, welcome to the forum. Can't add much to what DD said except that the waste outlet pipes may be covered by square grey covers and so not be obvious. These just flip open. Most vans have them on the side along the lower edge of the body; some have them at the back. perhaps someone will post a photo (I can't, I'm clueless)
mel
Apr 20, 2009
5,569
949
Welcome to the forum Anthony, you wont regret yur purchase, bet your looking forward to your first trip away.
Depending on the age of your van the waste pipe on older vans is 20mm and the newer vans 28.5mm (this was my experience and may not be so on all vans)
Click here to give you an idea of what you are looking for it will give you an idea of the flaps Mel is on about as well, good luck
and if you have any more questions post in the relevant topic's and some-one wiil be sure to give you an answer.
2,399
Hi Anthony, welcome to the Practical Caravan forum
If you have any problems using this website please let me know and I'll try to help.
