Hello
I have an avondale dart 556/6 2005 can any one please tell me what are the correct tyres and tyre pressure for this caravan
Thank you
This discussion gives it as "We have a 2005 Dart 556/6 and this has a tyre size of 165/R13/C".
The pressure will depend on what is written on the side wall of the tyres you buy. You proportion max pressure to max weight and number of axles/wheels.
It has an MTPLM of 1300kg. I would think the pressure should be about 56 lb. Hope someone has more information though as difficult to find out without a handbook.
Not sure there is a plate showing tyre pressures on Avondales. I certainly never found one on our Argente it was only in the handbook which I no longer have.
You might try this site for information. http://www.tyresafe.org/check-your-pressures/caravan-pressure-calculator/
The pressure per tyre will be:
[MTPLM] divided by [number of tyres] divided by [Max load printed on tyre side wall] multiplied by [Max pressure printed on tyre side wall]
The above formula allows for different manufacturers giving different max load @ max pressure figures. Just because one person has their tyre at a certain pressure it doesn't mean the next person has to use that pressure iF the tyres are different.
