My OH is going mad trying to locate the source of a knock which appears to come from the Alko hitch, the towbar, or somewhere near that area. It is a definite knock when the car and caravan are going over bumps, it transmits and sounds to come from under the car, or at the very rear.It's nothing like the groaning or 'straining' that you sometimes get with an Alko hitch. He's checked the hitch head, and there's no movement, checked the overrun damper, no problems, regreased everything on the hitch, replaced the bolts securing the Alko head to the hitch again, as we had both bolts shear last year (which may be connected - service dept said that had never heard of it before).
The towbar is newly fitted, in about March this year, there's no play on the bolts anywhere. Our car is Mondeo Estate, and has spring assisters fitted to the rear springs. When we're not towing there's a very annoying, but much lighter 'rattling' sound which may come from the same source. The caravan is a Swift Speedbird, now ten years old, fitted with shock-absorbers, which he's also checked and which are fine. The caravan is newly fitted with a Ego motor mover, but nothing appears to be amiss with the fitting, which OH did himself and nothing 'knocks' when bounced around.
We've followed each other, towing, around our storage compound, listening to the knock - which is quite loud - but are not able to locate the source!
Any other suggestions. Box of chocolates for the person to suggest something which solves the problem! (Apart from selling the car/caravan -- we love them both!) He doesn't 'do' forums, hence my posting on his behalf!
