hi there, i'm not an expert but you may need a couple of new "O" ring closed foam washers which fit around the mounting attachments with fit to the roof of which the status 530 pole slides through. If you telephone Grade UK on Tel: 0115 986 7151 press option 2 for customer services, Harvey one of their advisers there is very good and I'm sure will be able to give you an exact answer. Grade UK are the people who make the status antenna. Hope this helps, let me know how you get on. Cheers! Andrew.
