help windows & keys
i have 2 problems i am looking for advice on. we have managed to lose the only set of keys we had, which were for the door, gas locker & toilet cassette door, any advice on getting in to caravan without wrecking it and being able to replace locks?
also someone has managed to through a stone through the front window so we now have a hole in both panes of front window, what is best method to replace or repair?
If the hole in the window is large enough to get an arm in, you could undo the catches and enter that way and open the door from the inside.
If the stable door has a window in the top half these are easy to "pop" out and put your hand in.
Once you can get a lock barrel out you should be able to identify the key number.
Mark we have just had to replace a side window on our van, as we were broken into, we found a place who do second hand windows, they are car and caravan spares 01832 205253 based in peterborough, very reasonable,helpful and the window was well packed
hope this is useful
sam
