HGV E charging points
5,467
Just seen this . I wonder if car and caravan , non EV, are allowed to use the bays for parking? Apparently these bays have replaced conventional ones.
9,363
I could not support a non EV outfit using them, but they should be available to EV outfits, but I doubt that they will be. After all a EV outfit can uncouple and park the caravan whilst the tow car charges its battery.
2,316
I honestly don’t know so the answer hence the question.
Does the plug in EV lead have the same configuration for a HGV as for a domestic electric car?
9,363
I think HGV will be around 350 kw but with the aim being 1 mw supply. Mind you when solid state car batteries start to appear range will be potentially twice that of lithium based batteries, or same range for a smaller battery. Much reduced fire risk and faster charging too. So I suspect caravanners may not be so range inhibited as SSB enter the market. Although those that do high miles per day with a van might still have to decouple.
A new instavolt multi bay charger near us and I’ve never seen a car plugged in yet. Because most motorists charge at home and possibly at work.
