Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
We’re currently investigating an issue related to the forum theme and styling that is impacting page layout and visual formatting. The problem has been identified, and we are actively working on a resolution. There is no impact to user data or functionality, this is strictly a front-end display issue. We’ll post an update once the fix has been deployed. Thanks for your patience while we get this sorted.
Hi. We have recently fitted a tow bar with the intention of purchasing our first Caravan. Would you recommend that we start off 'cheap' or bite the bullet and spend £15+k on your first buy?
Impossible to answer. You can buy a cheaper caravan that has been regularly serviced, damp free and in pristine condition. You can buy a more expensive on that turns out to be a real dog, and vice versa.
I would spend time visiting dealerships to look at types of caravan, layouts, prices etc then start to refine what you actually would like. One advantage of a dealership purchase is that you get the protection of the Consumer Retail Act 2015. Plus if you use a credit card for part of your purchase you get CCA Section 75 protection. Or a loan taken out via the dealership gives further protection. For a private purchase you get virtually no protection if things go awry.
What car do you have as this will define to a large extent what caravan you can tow.
Consider the layout you want. As we have a super king-size bed at home we knew we'd struggle in the small doubles in vans. So we went for twin beds. Also look at what weight of van your car will tow.
Welcome to the forum. Enjoy your caravan shopping. If buying privately, spend a bit extra and gather a local caravan technician to give it the once over including a full damp check for you.
Look on this website to find one
