Hobby caravan door lock.
Apr 22, 2025
Does anyone know what door lock is fitted to a 2010 hobby 650. The Hartal lock looks very similar, but at £100 don't want to find out if wrong one. My keys are number FW 125 IF THAT HELPS.
Many thnx
Apr 23, 2024
606
491
1,135
Please take a picture or your lock as door locks do vary even on the same make of vans from year to year.
940
Does the whole door lock require replacing or is it only the lock cylinder? I ask because you have given details of the key combination and that is specific only to the lock cylinder which can be replaced separately and you wouldn't need a complete lock assembly.
Apr 22, 2025
Hello, the two keys I have fit the gas lereeocker and the toilet waste locker. There is no barrel present in the main door. Do you think I can get a replacement barrel off the key numbers, if so, any idea where.
Regards
940
I got a new barrel for the door lock through the dealer after a key broke inside the lock cylinder and the remaining bit refused to be extracted. He did have to order it from the manufacturer in order to get the same combination as the other locks, but at a fraction of what a complete lock would have cost.
Apr 22, 2025
Appreciate your swift response, it does give me an idea of how to progress
Regards
