Feb 13, 2024
1,263
805
1,435
Following a horse box this morning, and got me wondering. The driver couldn't see behind as the box was wide. Should they be advised to use towing mirrors. If I was towing a horse box I certainly would. Your thoughts on this.
May 15, 2023
160
140
1,635
You need to be able to see clearly 4 metres to each side and 20 metres behind the rear of your vehicle, if they can achieve this they don't require towing mirrors.
4,003
1,751
Might have an electronic rear view camera system?
Hard to see just the one cm diameter lenes needed these days, peering at you.
1,263
805
1,435
95% of horse boxes are towed by women up here as its right horsey country. The one's driving the 3.5 tonners are the worst, they don't like it when you over take them when they are peedling along at 30MPH.
Sam Vimes
2,532
2,032
12,935
Perhaps it depends on which way the horse is facing. It could act as a look out :)
Reactions: Johnb
5,283
Perhaps but isn’t the point of extending door mirrors to see , say a cyclist , motor bike in your blind spot . The camera on the rear of the box doesn’t cover the car or box side
4,302
The law requires that the driver must have a prescribed rearward view of their vehicle and trailer. It does not prescribe that that view must be provided by extension mirrors. However when towing with most combinations of car and caravan, the standard mirrors or rear view system cannot provide the prescribed view, so extension mirrors are usually (but not always) necessary. The law in this matter does not differentiate between the purpose of the trailer.
I am however highly upset at some of the views expressed in this thread. they are bigoted and inflammatory and directed a perfectly legitimate type of road user. Why this was started and allowed to be perpetuated in a caravanning forum topic area for "Caravanning" I do not know.
Even if it was meant to be a humorous topic, it misses that mark by a country mile, and I think it should be removed completely. It is totally inappropriate.
For the record I do not tow horse boxes, I am just appalled at the hypocrisy shown but forum members.
2,217
Moderator note.
I did see Borderbillys comment and considered whether to let it stand. I took it as a daft remark designed to ruffle some feathers. Over moderating is as risky as under moderating so, on this occasion, left it. Should the comments intensify they will be removed.
Can I suggest we just ignore it and return to the towing mirror discussion.
5,203
I thought the initial post was a light hearted comment. It is just as bad being stuck behind a driver that dithers all over the place not knowing if they are going to turn left or right, is doing 20mph in a 60mph zone and then when entering a 30mph zone speeds up! Plonker!
Reactions: borderbilly
Sam Vimes
2,532
2,032
12,935
When I first saw those comments I thought the same as Mel but decided to let it run anyway - even adding my own 'daft' comment.
Maybe some members would be wise to take note of Plato before posting some fatuous comments.
But then that would spoil some of the fun sometimes :)
quote-a-wise-man-speaks-because-he-has-something-to-say-a-fool-because-he-has-to-say-something...jpg
Jul 15, 2008
3,895
1,077
......anyone driving the roads today and puts safety first knows there are some appalling drivers around.
Towing a caravan will quickly bring that to your attention and I'm sure drivers towing horseboxes experience much the same.
Sep 26, 2018
731
290
19,135
Having towed a horsebox trailer many years ago and for many miles, don't criticise until you have been in their shoes. One thing you have to remember is that the cargo is up to a ton of live animal, and they DO NOT stand still. Even with a Scott Stabiliser fitted (that's all that was available then) they could make the trailer move around, and cornering is nowhere near as easy as with a caravan. Back in the day we moved on to a 7.5 tonne truck based horsebox within a couple of years.
5,203
When I see a horsebox on a road , always give them a wide berth take it slow when passing 🙏
I think the idea is to get past them as quickly and safely as possible as there may be cars behind you that would also like to overtake the horse box while the road is clear?
