How do I know which fridge I've got?!
May 12, 2014
90
7
10,585
I've got my new (to me) caravan home on the drive and having never used a van before, thought I'd put my sensible head on and read some of the instruction manuals before I start randomly pushing buttons. It's a 2011 model Coachman Amara 570/6, private sale and came with about 3 weeks' reading worth of instruction manuals for every conceivable system ... apart from the fridge.
No problem I think, I'll just download one from Thetford's website. However .. there appear to be many different models of Thetford fridge. The caravan user manual simply says that it is fitted with a Thetford fridge and to see the technical data specs for full details. The technical data booklet gives no details at all on the fridge. I can't see any visible markings at all in / on the fridge to tell me. Is there any way to find out which one I've got? For something which apparently will run on 230V, 12V or gas I can only see 2 buttons on the fridge so I'm loathe to just dive in and start pressing them in case I burn the van down!
1,662
On ours you had to move the salad tray to see the label.
The coachman brochure for 2011 says it is a 107 litre fridge with electronic i ignition, if that is any help
3,580
Tuffty, I think you have the Thetford N 107. I had same fridge fitted to my 2010 545 VIP.
I think Martin 24 might be able to confirm.
Hutch.
Aug 23, 2009
3,167
Martin 24 can confirm it will be a Thetford unit because he had so many problems with his resulting in a replacement which also played up. Yes Hutch I think it will be a 107
1,662
It will be a 107 cos that what is says in the brochure for 2011 Amara. See my post further up the thread.
Strewth!
3,580
Tuffty, I think as we have all decided it is the 107 liter fridge as all hand books manuals, an of course the lovely Lady Mel has said. I have found out that the 107 liter fridge is marketed as the Model N112, found this in the Thetford owners manual PDF.
Hope this helps.
May 12, 2014
90
7
10,585
Thanks everyone. As suggested the label was behind the salad tray at the bottom of the fridge. It is a 107 litre model, confusingly called the N112! Thanks for the help
