How many solar panels can I have?
Dec 8, 2021
9
4,515
Hi,
We're currently away camping off grid for the first time. I've been wondering if this is possible/sensible... Having multiple solar panels fitted to a caravan roof to charge an EcoFlow/jackery battery on-board which we can use to supply our caravan with 240v/recharge our leisure battery?
I find that having solar panels flat on their back is not optimal for generating solar energy, but multiple panels will supply a more meaningful charge.
I've been hauling my panel and battery around the caravan whilst onsite, but pack it away when leaving the van. It would be lovely to gain charge whilst not at the caravan. I lost 6 hours of charging time whilst on a bike ride yesterday. Anyone done anything similar?
4,230
1,951
Up to a point you can but you could quite easily , quickly run into the charging limits of the unit you have.
Taking the EcoFlo Delta 2 as an example.
This power bank has three solar input limits, 500Watts, 15 Amps and 60 Volts. With a warning exceeding the latter can damage the unit. The 500Watts clearly means you can't have both the 15 Amp & 60 Volts limit together, as that's 900 Watts.
Wiring them up has to be considered and what might be a tolerable configuration in dull conditions could do damage should briefly the clouds part and the sun wink at the array.
Much the same logic comes into play with fixing panels and the effect of the suns angle through the day and through the year, what is "safe" at 9am could be unsafe at real noon. What is safe in the low seasons will be way unsafe in the summer.
IMO your best option is to settle for a 500Watt array wired up in series to yield as high a voltage as your panel options give (*) and power bank can tolerate, but in this you need to keep the panels well matched.
Taking the EcoFlo Delta 2 again, and the more readily available panel options, that tends to limit you to two 200 to 250 panels wired up in series to get about 45 volts.
It would be nice if you could better exploit the EcoFlo's 60 volt limit but getting panels with their open circuit voltages up beyond 24 volts, or lower than 20 volts could be challenging.
(*) the higher we can get that notional input voltage from the array, the higher will be our yield under poorer solar conditions and I would suggest that is our real life aim.
We have typically no real challenges on blazing sun days, as campers our real difficulty is getting enough on a series of overcast days.
Unfortunately quite a difference to the solar industries own goals, simply getting the maximum they can, their kit is tailored to that.
I would with my EcoFlo like to have three 167 Watt panels with open circuit voltages of just 20 Volts and optimum output voltages very close to that, so I could get the best available yield on overcast days whilst not risking doing damage on sunny ones.
Your conundrum is one I presently am facing, I have the EcoFlo powered by a Excel Power 200Watt panel but might invest in a second identical panel. I have noticed the EcoFlo , compared to my Morningstar PWM system charging the caravan's battery, does not switch into charge at as lower voltages. So it does not achieve as much in that more critical low light conditions.
I have thought of altering the 200 Watt array's wiring of its two panel from its out of the box parallel to series, just screwing up its 5 year warranty holds me back at the moment. Given a bit of time, better performance during so much of its usage might well be more motivating than being in a possible warranty claim position.
I did discuss this with the supplying dealer but I felt they were missing the underlying logic of the technical argument, we as campers would be better served by arrays that work as well as possibly under low light conditions rather than be extra good under ideal condition. I note now that Excels 440 Watt array does just that, but I could not bring myself round to shelling out the extra money, possibly a poor decision in retrospect though at the time I did not know these finer but important details. ( should have done more homework pre being seduced by the offers at the time!)
2,696
My latest caravan came with two solar panels so I hoping it keep the battery well charged because our seasonal site is on a electricity pay as you go metered system .
Nov 30, 2022
2,021
1,930
5,935
Freeman3030
One of the first things you need to consider is the weight of anything you permanently add to your caravan. Caravan payloads are notoriously meagre and running overweight can cause you a lot of grief, and money, if/when you get caught doing so.
4,230
1,951
Freeman3030
Whilst quite true and very valid, the more modern polymer arrays are so much lighter than the glass type, along with some having significantly improved efficiencies.
My new 200 Watt array is 5 Kg (*), my old (2007) 85 Watt panel is 9 Kgs.
As said though a very valid point to watch, and even motivate array choices nevertheless.
(*) its protective case adds another 2 kgs if that's taken.
Reactions: Mr Plodd
4,230
1,951
An Excel Power 440 Watt array, two screw in ground anchors and a half decent securing chain/padlock, then risk it.
The two screw in ground anchors with the security chain run through them can be configured so they can't be simply unscrewed out, and I suggest few fellow campers carry bolt croppers and the intent to go sealing solar arrays.
Like me you probably need to come to terms with taking on a bit of risk to be free to do what you go camping for.
Breaking into your van and running off with your EcoFlo would be way easier ;)
Reactions: Mel and otherclive
Dec 27, 2022
735
508
5,135
Strikes me this whole portable 230v thing is just the wrong way to go about it.
It would be far more efficient and cost effective to fit a LifePo4 battery to the caravan and fit a decent inverter and solar panels.
The panels would charge the LifePo4 which could provide all your 12v needs and with the inverter your 230v needs as well.
Since fitting a 130w panel and LifePo4 battery I have not needed to use EHU to charge batteries at all.
The only things in the caravan that it can't supply 24/7 are the heating and fridge which can run from gas, the kettle/toaster/microwave can run from the inverter. There are no other 230v items in our van the TV etc are all 12v.
We use about 30% of the battery capacity in a 24hr period and this is usually replaced by mid afternoon, a second panel would decrease this time and the amount drawn from the battery.
Reactions: ProfJohnL
4,230
1,951
Another solution for some aspects, but still requires purchase of that battery, a matched solar controller and the inverter, which as a package is the likes of power banks as EcoFlo, Jackery etc, etc.
These are not uniquely a mains supply but can be 12 volt and a whole range of USB outlets.
Add to that these units are not van unique, they can be used at home, in the garden with power tools and as I do when out picnicking etc.
Also some can be charged in cars on route and from mains.
I am also not convinced with the claim the that piecemeal gathering together a system is "far more efficient"? If then only rechaging the vans battery then things will change.
More likely IMO that the development of the matched componentry that the likes of EcoFlo must have invested in their products is going to be more efficient that we are buying bits and DIY-ing the system?
It's IMO missing a point to see them as an replacement for a van's 12 volt system but more a complimentary wider use system, and by all means use Lithium in the van if the ancillary systems are compatible with that battery technology.
Finally it does not resolve the OP's issue about leaving the panels out when away, nor a remedy with adding large amount of array to offset things when back; the kit still has to operate within the components limits
4,473
If the only intention of adding solar panels is to recharge your caravan's battery, then the process of adding a "power station" is not the most sensible or efficient solution. The idea would work, but it would be more efficient, and have a lower weight and cost penalty to use Gumpy's idea in #7.
If your intention is to use the "power station" for other activities outside of caravanning, then your use case changes the cost base for the reasons JTQ has outlined in #8
2,808
Freeman3030
My new van has a factory fit panel. I do not know the weight but it looks substantial. I just wonder why. In 2015 I fitted a panel to my van. It was flexible and was fitted by glueing. It worked very well for a fraction of the weight.
4,230
1,951
Arguments supporting the use of the panel that they fitted might be found in, glass being cheap, being very effective, easier to cool, not overly effected by thermal expansion and immune to UV degradation as fitted to the roof its likely to be subjected to UV damage. The latter from its fitment onwards, whereas most of the polymers are degraded by UV, some way more than the better ones.
2,808
Points taken, but mine worked well for the 5 years I kept the van.
685
320
2,135
The flexible panels are lot lighter but tend to have shorter life. I fitted one to first caravan and made sure to allow air gap when gluing it. If I did it again would glue rails to roof then attach panel to them so it is easier to replace in case of failure.
Current 250W solid panel that came with van probably weighs 20kgs with fittings, big hit on payload.
I'm also looking at going down portable power bank path as reduce weight in van. When travelling charge in car from 12v outlet or 230VAC outlet at cafes, laundry etc. Onsite from roof top panel when out and about. Use fliexible one facing sun when hanging around van.
Suspect most of 12V demand can be supplied from power bank 10Amp outlet. For high use cases can use van 230-12V powersupply powered from powerbank 230v socket.
For those with motor movers Li Ion motorbike starter batteries will do job, only weigh 1kg and can jumpstart car if needed, been there done that few times. In this situation would keep MM 12V totally separate from caravan 12V system. I charge it with 1A gelcel charger.
For supplying 230vAC either plug appliance straight into Powerbank outlet. Alternatively power van from Power bank, means all 230V outlets in van can be used. May mean run cable from powerbank out window to van EUH input For those euro vans that have 5L 300W Truma Therme water heater this would be way to go. Allow 300WH per shower.
Power banks are cheaper more verstile option than going down LiFeP04 house battery path. A 1024wH Power bank comes with solar, high power 230v (1hr charge and 12V 8amp chargers built in. 1800W 230V outlets, 12v 8-10A outlets, multiply USB outlets. Remote monitoring and control via BT and ph.
Compare that to fixed option. Which will add +30kg to payload by timing wiring, fuses and breakers are added.
12V 100AH battery with BT monitoring 14Kg
Solar charger typically 15A
230V charger typically 10A
2000WH 230v inverter.
USB outlets in van.
