How to charge caravan battery whilst towing ?
Dec 16, 2007
285
Hi All
Probably a bit of an easy question but I have just had the white socket fitted to my towcar and tried it out for the first time today, I put the rocker switch inside the van onto car, however, even with the engine running the level of the battery didn't move from red. I then switched it to caravan to find the battery level at the top of green.
What position should I put this switch on (van, off , car)
I switched the red button on the fridge on and the light came on. Am i doing this correct ?
Many Thanks
Ian
Dec 12, 2005
123
Hi Ian
See my reply in "Fridge change over switch" on this subject. Basicaly according to my Swift Owners Handbook, if the plugs are wired up correctly, then when towing, the rocker switch should be in the "central" position, then when the engine is runnig there is power going to the fridge, so long as that is switched to battery operation & there is also power going to charge the van battery. I have a 2004 Swift and the instruction applies to all models, certainly those built in 2004.
I have always done it this way and never had a problem!
Tankie
Dec 16, 2007
285
Hi,
Today I wanted to try to see if I could power the vans lights whilst connected to the car.
I connected the grey socket, started the car engine. I then turned the caravan switch to "car" and turned on the 12v halogen ceiling light, nothing, I then switched it to "caravan" the level went upto green and the light came on.
Was the battery still being charged whilst the switch was on caravan or does it only charge in "on" or "car" if so how can I charge the battery off the car and run the interior lights ?
The van is a 2000 challenger incase this helps.
Many Thanks
Ian
Ian, the answer is it all depends upon the modle of control Unit you have fitted!
On my 2006 Ace Award the switch works like this:
Van position: The van battery will feed the 12v electrics and be charged from the battery charger whilst on EHU. In this position the van battery willbe charged from the car en route.
Centre position: The van battery is disconnected and the 12v electrics will run only from the charger whilst on EHU. The battery will not charge from the car whilst en route.#
Car position: the van 12v electrics are fed from the car supply on pin 4 of the 12S. The van battery will not charge in this position.
Your info "I connected the grey socket, started the car engine. I then turned the caravan switch to "car" and turned on the 12v halogen ceiling light, nothing, I then switched it to "caravan" the level went upto green and the light came on".
This a bit confusing as with switch in the van position the 12v lights etc. should be isolated when the car engine is running. There is a "habitation" relay in the van which is switched by the fridge supply on the 12S. When the relay operates the van 12v circuits should be isolated from the van battery and the supply on pin 4 of the 12S fed to the van battery to charge it.
What make and model of control unit do you have?
Dec 12, 2005
123
Beats me why they keep changing the systems.
There cant be a lot of difference between charging the van battery through pin 4 & running the fridge, through pin 6, when the engine is running and the switch on the ESM4 is in the central position as it is on my 2004 Charisma.
What I cant understand is why Ian wants to run lights in the van, when the engine is running,as usually, when engine is running the outfit is moving. If its just a flat battery he is trying to overcome, on site and there is no EHU or generators available, personally I would remove the battery, SECURE it in the back of the car, connect it to the 12s and go for a run for an hour or so.
This may be inconvienent, but it would avoid exhaust gasses getting into the van zzzzzzzzzzzzzzzzzz!
Tankie
Dec 16, 2007
285
Hi both thanks for your advice,
Basically what I am trying to achieve is that if we are on site without hook up and the wife is half way through her shower can I simply connect the car and leave the van on "van" as if I put it on car this would cut the power for the interior therefore cutting out the water pump.
The unit is a plug in systems not sure of the model number though sorry and unable to find it till next week as the van is in the dealers having warranty work done. It is 2000 Challenger if this helps.
I think the way it should be done is 1) Switch on car when towing and 2) switch should stay on "van" when on site and in need of charge.
Am i correct ?
Your replies are greatly appreciated !!
Many Thanks
Ian
Dec 12, 2005
123
When switched to "CAR" all 12v circuits in the van should work! so there should be no interuption to the pump, I'm assuming the water is being heated by Gas!
Dec 16, 2007
285
thanks for the reply, we heat the water on gas when no ehu and also the fridge and heating work on gas, the tv and lights run off battery.
I have tried working the interior on "car" and nothing happens when i switch to "van" the lights come on. Is this something that should be checked with the van still in the dealers ??
Many Thanks
Ian
ian in reply to your question " have tried working the interior on "car" and nothing happens, when I switch to "van" the lights come on". There is something wrong. I am saying that on the assumption a)The car is connected to the caravan via the 12S. b)the car engine is not running.
To sum up:
With the car connected to the caravan via the 12S, and the engine NOT running, you should be able to switch between car and van positions and internal 12v electrics should work in both positions. Does this happen? I assunme not from your last post - it only works on the van position?
If you then start the engine the internal electrics should not work in either position. The fridge should get the supply from the car and the van battery should charge from the car.
Please confirm: Have you got 12 (+ve) on pin 4 of the 12S with (-ve) on pin 3? It should be there no matter whether the car engine is running or not.
With the switch set to van and the van internal lights switched on start the car engine. Do the lights go out?
Dec 16, 2007
285
Hi Ray
Unfortunately i have not had a good chance to have a look at the socket therefore can't answer your first question.
When the switch is on "van" and the engine is off the lights are very dim and barely on, I then start the engine and the lights go bright.
When I turned the fridge on battery the light didn't come on then after about 20 seconds it came on. I don't think the white socket has been used very much as we have not used it and we are unsure for how long the van was at the dealers.
Many Thanks
Ian
Ian
"When the switch is on "van" and the engine is off the lights are very dim and barely on"
This indicates to me that the van battery requires charging.
"I then start the engine and the lights go bright".
This indicates to me that at this stage the car is not providing the fridge supply on pin 6(+) and pin 7 (-)i.e. the car relay has not yet operated and therefore the car supply on pins 4 (+) and pin 3 (-) are feeding the van 12v. This is not ideal but is not a problem as such[see my next comment].
"When I turned the fridge on battery the light didn't come on then after about 20 seconds it came on".
This indicates to me that the car relay operated after 20 seconds thus feeding the fridge and in addition operating the "van habitation relay" which should have switched of the van lights and fed the supply on pin 4(+) & pin 3 (-) to charge the van battery. It is fairly normal for the relay to lag in operation at engine tickover as it is voltage sensing. If the engine had been revved it would have propably operated straight away if not it requires adjusting.
Are you happy with the way it should work now?
Ray
Dec 16, 2007
285
Hi Ray
Thanks for your help on this it is greatly appreciated.
The van has been in storage for about 5 weeks with the battery onboard so it was probably flat.
The fridge light reamained on for the 30 mins it took to get the van to the dealers so the delay must have been what you explained.
Thanks again for your great help !
Ian
Ian, if you have any further problems ask the moderator to allow you to send a message to me on my email address- it will be much easier by email than the forum. Ray
chenzhen
BANNED
May 19, 2016
99
"The word vintage, used to describe dresses and clothing, is a broad term that is generally used to refer to clothing that originates from a past era. In general, clothing that dates earlier than the 1920s, is considered to be antique. Whereas clothing and dresses that have emerged after the 1920s, up to the 1980s and 90s, is considered to be vintage. Retro, or vintage style, usually refers to clothing that is an imitation of the style of a previous era.
A range of vintage style clothing that is hugely popular today, are the fifties dresses. The enduring popularity of these dresses, might be because that was the time women's clothing made significant strides, as it was after the second World War and many restrictions had been lifted and designers had more freedom and materials available to create beautiful women's fashion ranges.
Some of the popular dress styles that have enjoyed a timeless appeal have included the Ophelia dress, floral tea dresses, Audrey Hepburn style dresses, the figure hugging Lindy Bop dresses and dresses made famous by Grace Kelly and many classic Hollywood stars. Even today, young women are choosing vintage style dresses for their special occasions such as a ball, prom night, and other formal parties, because they have a definite charm and elegance and have been designed to enhance a woman's shape and beauty."
fake oakleys
michael kors uk
cheap ray bans
rolex watches for sale
nike free flyknit 5.0
ugg boots
coach outlet online
yeezy boost 350 white
michael kors bags
air max 90 white
ralph lauren outlet
louis vuitton bags
converse sale
coach factory outlet
adidas shoes
nike free flyknit 3.0
burberry outlet
nike air force
cheap ray-ban sunglasses outlet
tory burch shoes
nike tn pas cher
chaussure louboutin
adidas nmd runner
louis vuitton handbags
skechers outlet
oakley sunglasses cheap
cheap jordan shoes
ray bans
adidas nmd black
reebok classic
adidas trainers
vans store
nike cortez white
pandora charms
air max 90
adidas shoes
fitflops shoes
timberland uk
pandora charms uk
armani exchange
burberry bags
under armour
louis vuitton outlet stores
oakley sunglasses wholesale
pandora jewelry outlet
cheap basketball shoes
ferragamo
ralph lauren
pandora rings
toms outlet
michael kors outlet online
prada sunglasses wholesale
cheap ray bans
www.coachfactory.com
cheap air jordans
michael kors handbags
valentino
michael kors outlet clearance
michael kors outlet
ugg boots
ralph lauren
ghd
mizuno running shoes
nike air force black
cheap jordans
nike free run flyknit
cheap ray bans
sac longchamp
kate spade outlet
cheap ray ban outlet
ray bans
true religion jeans
babyliss hair dryer
michael kors bags
true religion outlet
reebok outlet store
ray bans
nike trainers
polo outlet
fitflops
adidas superstars
true religion outlet store
kate spade uk
discount nike air max
ray ban sunglasses outlet
jordan pas cher
levis 511
nike huarache
omega speedmaster
christian louboutin uk
michael kors outlet store
tiffany jewelry outlet
polo ralph lauren men
adidas supercolor pink
rolex replica watches
ray ban outlet store online
cheap nike air max
coach outlet store online clearances
tory burch flats
hollister hoodies
nike cortez shoes
louis vuitton outlet online
hollister hoodies
pandora jewelry
louboutin outlet
coach factory outlet online
adidas pure boost black
designer handbags wholesale
yeezy boost 750
true religion
kate spade outlet online
tiffany uk
lebron james shoes 12
red bottoms outlet online
cheap jordan shoes
jordans
gucci borse
gucci handbags outlet
ray ban sunglasses sale
lacoste shoes
bottega veneta shoes
michale kors uk
ray ban sunglasses discount
louis vuitton uk
cheap ray ban sunglasses
longchamp outlet
micahel kors
adidas superstar white
air max
cheap nfl jerseys
burberry outlet
christian louboutin outlet
hollister clothing store
oakley sunglasses outlet
ralph lauren
nike blazer
michael kors canada
birkenstock sale
cheap ray bans
white converse
louboutin pas cher
jimmy choo
ed hardy uk
bottega veneta sale
north face outlet
nike air max 95
burberry sale
abercrombie and fitch outlet
hollister kids
louis vuitton purse
supra outlet
nike huarache black
nmd adidas
asics running shoes
lacoste polo shirts
jordan shoes
michael kors canada
abercrombie & fitch
coach outlet online
tiffany jewelry
burberry outlet canada
ray ban sunglass,ray ban sunglasses,ray ban outlet,cheap ray bans,cheap ray ban sunglasses,cheap ray bans,ray bans
ralph lauren outlet online
canada goose outlet
mlb jerseys wholesale
vans outlet store
birkenstock sale
coach purses on sale
ferragamo outlet
valentino bags
rolex submariner
mont blanc outlet
hollister co
nike air force
the north face outlet
armani outlet
tiffany and co outlet
michael kors handbgas
cheap oakleys
north face jackets
dior sunglasses 2016
coach outlet online
north face uk
kate spade bags
polo ralph lauren outlet
ray ban outlet online
adidas nmd uk
ghd hair dryer
jordan shoes
hollister uk
michael kors uk
buy red bottoms
nike roshe run
kate spade outlet
toms shoes
cheap oakleys
louis vuitton factory outlet
polo ralph lauren outlet online
puma outlet
true religion uk
chi flat iron
fitflops sale clearance
true religion jeans outlet
michael kors outlet canada
michael kors outlet
oakley sunglasses
instyler max
true religion jeans
fitflops
fitflops shoes
polo ralph lauren
pandora sale
michael kors outlet stores
hermes outlet
cheap oakley sunglasses
nhl jerseys wholesale
toms outlet
longchamp uk
timberland shoes
asics gel kayano
michael kors outlet
ed hardy
polo ralph lauren
versace sunglasses wholesale
louis vuitton borse
kate spade handbags
new balance shoes
versace sunglasses
birkenstock outlet
oakley sunglasses,oakley sunglass,cheap oakley sunglasses,oakley sunglasses cheap,oakley sunglasses outlet,oakley store,oakley outlet,oakley outlet store,oakley sunglasses sale,oakley sunglasses discount
michael kors bags
birkenstocks
nike air max 90
timberland boots for men
kobe bryant shoes
adidas shoes
birkenstock shoes
christian louboutin shoes
under armour outlet store
rolex daytona
michael kors outlet
abercrombie outlet
birkenstock uk
cartier
omega
polo ralph lauren
true religion sale
burberry outlet stores
nike shoes for cheap
nike store uk
sac longchamp pliage
nike force 1
ecco outlet
coach outlet online
louboutin shoes
canada goose jackets
nike free runs
reebok
converse outlet
coach outlet online
stephen curry basketball shoes
hollister kids
jimmy choo outlet store
nike air max 90
hermes belt
louboutin shoes
supra store
stan smith adidas
toms outlet
rolex watches uk
wholesale nike shoes
gucci outlet online
yeezy boost 350
nike free 5.0
cheap nfl jerseys
reebok shoes
coach outlet online
coach outlet store
tiffany and co jewelry
timberland shoes
ray ban outlet
timberland boots on sale
cartier love ring
white converse
louis vuitton purse
air max 90
ralph lauren pas cher
air jordan shoes
prada handbags
michael kors canada
holliste sale
adidas gazelle
nike flyknit racer
oakley sunglasses uk
yeezy boost 350 balck
lebron james shoes 2016
ralph lauren outlet
nike running shoes
kobe 11
nba jerseys wholesale
coach outlet store
michael kors handbags outlet
hollister clothing
louis vuitton pas cher
ralph lauren sale clearance
cheap oakley sunglasses outlet
"One of the most popular, but simple fifties dresses, is the petticoat. This was designed to be flattering to a lady's shape and also, to enhance the dress she was wearing over it. Petticoats made of silk and woollen materials were initially introduced for women to wear under the main dress, as they provided warmth and would enhance women's busts. The classic petticoat then became shorter and lacy petticoats became the fashion, as they delicately accentuated the dresses that were worn over them, such as the Ophelia dress.
Vintage style dresses UK are available in a wide variety of sizes from vintage clothing shops, textile fairs, auctions, flea markets, estate sales, antique markets, garage sales and collectable fairs. However, there is always the risk with buying genuine vintage clothing, that the sizes may not match current clothing sizes. But there are a number of special boutiques online, who specialise in designing and creating vintage clothing to order. They can take your specific measurements and produce an outfit that will be tailor made and fit you perfectly"
HFH
