Bailey Vendee 2004. Has standard external supply option, i.e. Aquaroll. I wish to create an internal position for the water containment being switched from external to internal supply without too much fuss. It would seem that the actual piping and supply will present little problem, but use of shut off valves and teeing. However the electrics to the second inlet module need to be connected to the existing internal wiring. Can this be done by splicing into the three cables already connected to the caravan wall mounted inlet ?
