Ray,
Ammeters need to be inserted into a circuit, so they become "a part of" the live feed wire - and measure the current flowing in that wire. Unlike Voltmeters which are used across the supply and measure the difference between live and return.
What ammeter have you bought? Were you thinking of using a DIY multi-meter on the current setting? or a "clamp-on" meter? or have you bought a commercial meter system with a remote (low voltage) display?
"Clamp on" AC meters that detect the current flowing in the wire from outside - without breaking into the circuit - are safe, but reasonably expensive, and not particularly accurate (most are intended for use with 100's of amps - and not trying to differentiate between 4 and 5 Amps)...
And there are some issues here: An "in-line" ammeter would need to be inserted between the EHU socket and the caravan MCB / RCD "fuse box" - so that you measure the total current flowing into the caravan - and that's not an ideal situation for a DIY project.
Why? Because if you want to read the meter display, that needs to be somewhere convenient - and the foot or two of cable that links the EHU socket to the "fuse box" won't be. And extending the live wire isn't a good idea.
It would be OK if you have a sealed meter with a remote (low voltage and safe) display.
Hobby multi-meters just aren't meant for this type of use (no possibility of permanent connection - and connectors that easily pull out are "lethal")
If you insert the ammeter after the "fuse box" then you'll only measure that circuit, and not the total...
Thinking further on this, a project that involves inserting a meter into the 240 volt AC supply, before the MCB and RCD trips - and asking how you could do this - are not a great combination.
It might be best for this to be done professionally...
Robert
