someone posted once a long time ago how one can make a mains adaptor for the aquaroll with a ball valve, I can't find the instructions does anyone out there know how
alwyn
alwyn
http://www.screwfix.com/app/sfd/cat/lrgimg_popup.jsp;jsessionid=05PPRW3JQKESWCSTHZOCFFI?productId=14716&imageNo=null&ts=26429If you want to make a mains connection for the fresh water into the van you need the large aquaroll or water container with 2 caps
You buy from a plumbers merchant a torbreck valve and fit it into the side entry after boring the right size hole in the cap
The other cap entry is used for the submersible pump or inboard pump feed
