how to make mains connection wastemaster
Mar 29, 2005
92
someone posted once a long time ago how one can make a mains adaptor for the aquaroll with a ball valve, I can't find the instructions does anyone out there know how
alwyn
If you want to make a mains connection for the fresh water into the van you need the large aquaroll or water container with 2 caps
You buy from a plumbers merchant a torbreck valve and fit it into the side entry after boring the right size hole in the cap
The other cap entry is used for the submersible pump or inboard pump feed
http://www.screwfix.com/app/sfd/cat/lrgimg_popup.jsp;jsessionid=05PPRW3JQKESWCSTHZOCFFI?productId=14716&imageNo=null&ts=26429
Aug 29, 2006
291
you can also get the torbreck valve from wickes.
Take off the piece with the polythene tube on it.
Will
Apr 22, 2006
369
I also reckon that if you were to ebay this item the way that some of the sellers have the equipment laid out in the photo you would get a very good idea from that what goes where.
Its quite simple
If you look at the pic in the link above the torbeck valve just goes through the hole bored in the side cap,clamps to it with fittings included and the threaded outer end is the right thread to screw on a push fit water connector for the hose
Hi Ian
Its to enable use of the water point on a service pitch and its tokeep the aquaroll topped up thus saving carrying water etc
