How to remove awning lamp cover?
7,357
Hi,
I have a blown bulb in the awning light but for the life of me I cannot remove the cover. The Bailey handbook is no use. The light is a Ring Ultra with two 10 watt bulbs fitted. The van is a S5 Bailey Pageant. Any hints will be gratefully accepted.
Cheers
Other Clive
You have to hold it across the lens from top to bottom and squeeze while pulling
There are 4 little "lugs" (2top 2 bottom" that have to be disengaged
You can also do it with a flat table knife eased between the lens and frame
7,357
John,
thanks that worked fine.
Other Clive
Dec 30, 2009
1,662
Glad you can use your light in the awning. we have an abbey vogue 495 and for the life of me I cant understand why Abbey have positioned the outside light over the front side window, so unless you have the full awning up (once a year on main holiday)and not the porch its not in the awning!!!!
I must say its the most usless light ive ever had on any caravan owned. But its still me pride and joy
Kevin
