I suffer from the age old problem of rear waste outlets being unuseable on sites that slope so that you have to have the 'van rear end down to get it level.
I've though about re-plumbing the whole lot to exit just aft of the wheel on the off-side but hours messing about with slovent weld pipe under a caravan puts me off.
How's this for an idea? If i get 2 new waste outlet points and a lenght of 1 inch waste hose. Mount one outlet about 6 inches from the sink outlet and the other behind the O/S wheel [cutting a hole in the plasit skirt if needed. then join the two with hose threaded through the chassis & other pipes etc. the hose might not be a good fit but i'm sure jubilee clips or even some short sections of rubber hose could be used to make a water tight fit.
All i'd need to do is use a short hose to connect the two outlets together at the rear & collect the water from the center outlet. If you wanted the shower outlet to work too you'd need two lots of new pipe as I've found that joining the sink & shower outlets just leads to a shower-tray full of dishwater!!
any coments would be welcome!
Cheers Gareth
Cheers Gareth
