Indiana 12v extractor fan
Peter, simple question I assume you have switched the master 12v switch on the main panel to on? One switch on the fan controls on/off with extract out or supply in, the other the speed.
Thanks for your reply,
All switches are on. Read manual regarding using on 1 before 2 beore 3 so not to blow fuse. Opened roflight ok.
But it does not work. I know it is probably simple but quite frustrating. Any thoughts?
P.
As Tonyex says check the master switch. Look at the switch with the triangles or arrows on it. The one that points out of the frame switches it on to extract.
