Has anyone installed an instant electric hot water heater/shower in their caravan?
The power required would probably exceed the supply capability of most electric hook ups.Has anyone installed an instant electric hot water heater/shower in their caravan?
It does not require gas to work.The OPs question was about fitting an instantaneous "electric" heater shower.
What any uniquely electrical system can't do is add more heat energy to the water supply to the shower than the EHU lead can supply it with.
The ALDE Flow takes another route around that limit by being simultaneously able to exploit both the ALDE's LPG's heating energy, which is much higher than the EHU's contribution, along with the electrical energy.
Raising from a maximum energy output on electricity of 3 kW, to a combined LPG [even using propane] & electrical output of 8.5 kW; clearly a massive change. That potentially could be 9.4 kW if using butane.
It is a very effective solution to instantaneous shower heating but not one as requested uniquely achieved electrically.
It depends on your definition of "work", it most certainly does require gas to add more energy to heat the water than the modest 3.68 kW of power that the 16 Amp EHU can supply the van with.
Either the shower flow or delta temperature that can be added to the water feed, or both have to be constrained, as that is the only amount of power the EHU can supply.
Using LPG as I quoted potentially adds a great deal more.
That a continuous stream of hot water can come from a shower when using EHU alone can't be deigned, the adequacy is the point and with the limitation of just an EHU that is capped by the kWs the EHU can supply.
In many conditions, the use of gas and electric together will result in higher temperatures - the Alde coolant has a cut-out temperature of about 82 degrees but for much of the time will be operating below that when on electric only as the coolant is continually cooled by the radiators, convectors and hot water jacket.You can use gas and electric together on most models, but this only heats it quicker and not hotter.
What type of caravan do you have in mind, touring or static?Has anyone installed an instant electric hot water heater/shower in their caravan?
