This is partly in response to the battery charging question under technical-
We always carry a spare battery, a small battery charger and a 240V inverter - mainly because we do a fair amount of non hookups.
This covers a lot of situations/advantages
You can use the battery charger when on hookup to charge the car battery if necessary.
The inverter is always useful in the van for occasional mains equipment (laptop etc) when on hookup.
The inverter can be used in the car with the battery charger to charge the spare battery (cigar lighter socket voltages are regulated so will not fully charge a battery).
You can use this method to charge a battery en route to a destination, on a day out or during a normal working week.
Make sure you have an auto cut off charger or a meter to ensure you turn off when charged.
Should you run flat you can always ask a CL owner or pub owner if you can plug in the charger and battery for a while.
Inverters cost around £20 up, the charger cost less than £10 and you can get a leisure battery from around £40 up.
Together with our 20W panel we have not been without power yet, I did buy a generator a couple of years ago and only used it twice before we started using these methods.
