Hi,
I'd like to install an inverter into my Bailey Ranger 620/6.
I wondered if anyone has had any experience of this.
I propose to place it behind the battery locker with thick short leads to the 12v supply and then take the output straight 'into' the line that carries the 230v to each of my three sockets in the caravan by means of a simple lighting style junction box.
I'll only switch the inverter on when the caravans not hooked up. All should be well except two things concern me:
1) When hooked up to site mains, the output stage of the inverter will see 230v, although the inverter stage will not be on. Will this fry the inverter ? (of course I could unplug it if needed)
2) When the Caravan is not hooked up and I have switched the inverter 'on' it will take the 12v battery and invert it to a 230 sine / square output. This 230v will be present as planned on the van sockets BUT because its present there, since the whole 230v line is joined together, it will surely be present at the input to the battery charger... therefore the inverter will straight away become maxed out charging the battery its simultaneously draining... if you get my drift... Don't really want to mess about with a switch on the battery charger input if I don't have to.
Cheers, - well done to anyone who has read this to the bottom also.
Colin
Colin
