Apr 30, 2005
Hi all,
I purchased a Durite 1500watt inverter last year for my boat, never used it through, and have lost the instructions.
My querie is what could I run off this unit,what would be the ideal size battery,is ther a calculation to work out its power consumption etc?
I've just bought my first caravan, and I thought I could use the inverter in it. any comments would be gratefully recieved
4,407
Hello Andy,
Basically if you look at the current consumption of the 230V ac appliance you want to use (in Amps) and multiply by 21, That will give you the approximate current the 12V dc battery will need to be able to deliver. If you are seriously looking at pulling 1500Watts (1.5KkW) then the calculation will be 1500/230 = 6.52A now multiply by 21 = 137A at 12Vdc!
Of course if you only use part of the capacity, then the 12Vdc currant needs also drop.
What size of battery? - the biggest possible.
May 20, 2005
346
John L I dont know where you got your equation from
Ohms law
Watts = Volts x amps
so amps = watts divided by volts
1500/12 = 125 amps
howerver there will be losses when using an inverter which will push the amps up (may be this is john L equation )but it will bepend on the quality of the converter how big these losses are.
4,407
Ohms law
1500/12 = 125 amps
Hello Paul
You are quite right VA does = W
And Yes, I did allow for losses by using a current conversion of 21 rather than 19.1 In practice that usually works fairly close to real life.
The other alternative is to use your 1500/12 = 125A + 10% = 137A
It all depends on how you want to do it!
Cheers
