Isabella Magnum Awning
Apr 3, 2005
302
Hi Isabel, we have a Isabella 'all in one 360' it has steel poles and we use it all year round, its not made for the uk market, but any dealer will get it for you, its a bit bigger than the magnum and a lot more stylish (we think).
Have a look on the Isabella web site!
regards, Andrew & Sally.
Mar 22, 2007
32
Hi Andrew & Sally,
Can you please tell me if the awning obstructs any windows on the Indiana. We are in the process of buying a Indiana 2008 and our dealer told us that this would not fit.
spj
Apr 5, 2006
220
Hi Isabel,
I don't know if the windows will be a problem on your van but the awning is about 11 feet long, we are lucky with ours as we can have it either right at the front or between the first front side window and the door which makes the van lighter inside. The Magnum only needs a vertical strip around 6 to 8 inches wide of caravan wall at each end of the awning for the poles and pads to sit against. Only 1 strip is needed if you use the awning rail on the other end.
If you measure your van from the front awning rail at about waist height backwards, the other end of the awning will be about 11 feet away, if you have no windows within a couple of feet of this it will be fine.
Alternatively measure 11 feet from one side of the door along the van but do allow for the door to open flat against the caravan.
The all in one awnings from Isabella are also worth a look, it depends how much room you need and going from other comments previously made on this forum the repair service offered by Isabella (I have never needed it) is second to none.
spj.
May 6, 2005
37
Hi Isabel,
when we bought our Isabella Magnum at a show last year, the guy asked us what Caravan we had. When we told him he looked it up in a manual and told us how it would fit ie. Not cover any windows but would cover a locker.
I suggest you get in touch with Isabella and ask them as I'm pretty sure that this manual came from them. They can then look up your caravan and let you know what, if anything the awning will cover.
Brilliant awning by the way.
Hope this helps
Regards
Steve
