Jacking brackets
Sep 5, 2016
928
119
4,935
Anyone ever made their own jacking brackets that bolt on to the pre-drilled holes on the chassis rather than buy Alko or Purple line brackets,
Jul 22, 2014
329
I haven't, but would you propose to do your own welding? It would need to be to a high standard, and unless you have a pillar drill you are going to have some tedious drilling to do. Mind you, I have hand drilled 1/2" holes in 1/4" steel in the past :S
Sep 5, 2016
928
119
4,935
If you look at the Bailey caravan jack and bracket, the bracket is just a piece of flat bar bolted to the chassis with a welded box on the bottom to sit on the top of the jack, the Alko bracket is a right angle that is also bolted to the chassis, but the Alko jack head sits inside the bottom of the Alko bracket, actually not much welding in the way I will do it, a piece of flat bar, drilling the holes not a problem, my bracket will sit inside my jack heads, infact the opposite way round that Bailey do it,
5,445
Hi Camel.
The OEM Al-ko brackets are dangerous imo.. Poorly designed and engineered . Note the failed one next to the other and the new Purple Line ones. Just ensure you make yours more substantial than the OEM B)
Sep 5, 2016
928
119
4,935
Dusty,
The Alko one's look like they are made from aluminium, cheers food for thought , :)
9,321
camel said:
Dusty,
No the Alko ones are galvanised steel. They produce two sizes the 800kg and 1000kg. The latter look much like the red ones in the above picture.
Sep 5, 2016
928
119
4,935
And the brackets retail in the £40.00 price range, I'm going to fabricate my own for a £10.00,
Sep 5, 2016
928
119
4,935
There's a pair of Alko 800kg brackets on there at the minute and some mug wants to pay £20.00 + postage,
