Thanks Damian,we bought our van 5 months ago and have read the litterature many times and i can't say i have ever seen anything about corner steadies.So thanks for the info it is much appreciated and so i will leave the jockey wheel down as i do.Cheers,Kev.Hi Ian,
that well could be the answer mine is a solid jockey wheel not a pneumatic one so yes that prob is the answer.Many thanks,Kev.
Kev, due to the slope on our drive I leave the brake on all the time with no problems.I leave mine down, but this has got me thinking (bad idea)
so I get on site level the van and wind the steadys down if they get wound a fraction too much the weight comes off the jockey wheel and onto the steadys any way, if you wind them down but a fraction less than is needed, the caravan isnt quite as steady as it might be and moves when your inside.
So I guess it doesnt realy matter cus unless you wind the steadys to the exact point the weight is either on or off the jockey wheel.
BTW when we had the storms a few weeks ago the van moved sidways front towards the house and rear away because of the wind buffeting the side of the van, jockey wheel down 1 front and 1 rear steady down with the brake off. I now apply the break if the wind is strong.
Kevin
Think I might now as I dont want to dent my pride and joy for the sake of the brake being offKev, due to the slope on our drive I leave the brake on all the time with no problems.
Wind up as in take more loadI thought that it was so that you could move the van and that was why it is a wheel
I always leave mine down with the steadies down of course yet when I come to wind the steadies up with the cordless drill I usually have to wind up the jockey wheel to take the strain off them before the drill can take the load
This would seem to indicate that they have gradually over a week or so been taking more weight than the jockey wheel
So could that mean if concerned a regular regime of relative stress testing each day or more often even??
LB our drive is quite steep but I always chock the wheels and release the handbrake after the brakes stuck on one winter and the van had to be dragged to release them.
Agred but only if they are all taking it the same but as the front steadies are between the main weight and the jockey wheel they will take the strain first so you may need to wind the jockey wheel down further thus taking weight off the front steadies---regards its good to talkYou're quite right about all occupants on board could easily make a van rear heavy but as you say it will probably take all occupants to do that. I can walk to the rear of my van with no steadies down and it doesn't tip. Therefore my van is still front heavy even with me stood in the back.
But wether or not the steadies are strong enough to take the strain(which I think they would be). Why wouldn't you want to support using the jockey wheel too, seen as most of the weight is in the front(unless 5 of you are all looking out the rear window)?
Surely 7 points of contact means less strain on the other 6.
Dan.
