having problems with kitchen sink tap seems to have no pressure, during last holiday the pump gave up, no water to any taps, bought new pump all ok except kitchen, trickle of water only, what else could be problem please ?????
yes shower and bathroom tap are fine when sink tap is on both still run and kitchen still trickles, will check for lime scale,does the water run from the tap if you also open another tap at the same time?If so it may be the tap micro switch. If you have a pressurised system try removing the anti spray filter on the tap spout,it may be blocked with scale
