Hi John - would your X-Trail jack not do for your caravan too as presumably the Nissan jack is designed for a heavier lift? I've always just carried a bottle jack but had thought I might get away with using the Rav4 jack from my car should I have the need in future. Haven't checked for suitable location points, if any, on my Elddis as yet.I have one and its very easy to lift the van with it
It also fits the side mounting points on the X Trail and with the polystyrene removed fits the space in the car boot so only one jack needs to be carried
Its very important to get down on the ground and make sure that the jack is correctly engaged with the raised part across the receiver otherwise it will flirt our sideways when under load as has happened twice to me !!
I have got one and i think they are good but they have brotht a lighter bottle jack out any views on this pleaseHi RUSure
I haven't tried the Nissan jack for 2 reasons
1 I didn't have the Kojack brackets fitted to the van before I bought the Kojack
2 The Kojack is very easy to use being hydraulic and raises the car and van with ease
Remember the car jack is only deigned to lift one wheel at a time whereas the Kojack is designed to lift half a caravan
http://www.busyoutdoors.com/shop/towing/levelling/kojack-lite-caravan-jack/prod_449.htmlHi Ernest
I've seen the advert for the bottle Kojack and it looks as though it uses the same brackets
When you compare it with a bottle jack without the brackets elsewhere it seems very expensive
