leaked front window
Jul 15, 2005
2,175
How much water? Half full? or just a few drop inthe bottom?
It could be that you have a broken seal around the window, and if you can find out the trade name of the window - this should reveal the plastic used - and finally a suitable glue or solvent to seal the edge.
It could be that one or more of the black plastic ventillation plugs has fallen out from the inside of the window - if you remove the plugs and leave that winow in full sun - it should evaporte all the water in a few days. Then replace the plugs.
RECOMMEND HT OU
Jul 15, 2005
2,175
RECOMMEND HT OU
Jul 15, 2005
2,175
How I hate the text editor for this site.
In completion - Recommend that you purchase a copy of the "Haynes caravan manual - 3rd Edition" from Halfords or direct from Haynes.
This has a chapter on windows and Windows repair, plus a list of suppliers.
Robert
May 22, 2006
I had the same problem with about 1/2 inch of water inside the window unit. I drilled a small hole in the bottom corner and another one at the top. The water drained away and soon the unit was dry and has stayed that way until we changed the caravan.
