Keefanmaxx said:
I'm sure Prof will know the answer, but I'm guessing that you could reject the van as not fit for purpose, especially as it's already been repaired.
I'm unsure whether this will fall under the sale and supply of goods act or the consumer credit act.
Prof???
Hi.
As Grahamh points out this matter would fall under the Sale of Goods Act 1979, and not the later Consumer rights act 2015. However I suspect in this case the action that might ensue would be very similar under either act.
In this case if you wanted to pursue this under SoGA, you would have to be able to convince a court there is a fault in the design or construction of the caravan, and that the fault was present at the time of purchase.
Ironically the fact the caravan has been repaired once under the manufacturers guarantee could work in your favour, as the manufacture must have accepted the fault existed to have allowed a repair to take place. This is almost as good as an expert witness.
The other factor that strengthens that argument is the apparent fact the problem has reoccurred despite the manufacture having tried a repair.
These two aspects strongly point to either inadequate design or poor workmanship, on both the original ex factory products and further in the performance of the repair which has obviously failed too.
Assuming a court accepted the argument and awarded the case to the plaintiff, the remedy may be a refund, but it would not be the full price paid but more likely the current market value of an undamaged model, becasue you have had some value from the caravan.
Whilst SoGA can only be applied to the seller of the goods, there is the question of the failed repair carried out by the manufacture, which was carried out under a separate contract, Its possible the manufacturers guarantee is also subject to the rigours of SoGA or Supply of Goods and Services Act 1982
I suggest you seek advice from either the CAB, a solicitor or possibly your caravan insurer under their legal support.
Section 75 of consumer credit act would only apply if you used a finance arrangement to pay for some or all the caravan. the creditor is jointly responsible for the goods.
