leaking windows
hi guys hope you can help me. i have a problem with my omega 482 with those flat tinted side windows,they are leaking from the top of the window where it meets the seal.looking closer it seems as though the glass needs to press harder on the seal as it only just touches it when the window is closed.the seals look ok so dont realy want to replace them as it only needs glass to fit tighter on seals any advise would be welcome ps its a 2006 model
Hi,
I had a similar problem on our 2011 Coachman Pastice 460/2 with, I believe, similar windows. They appeared to leak at the top as you suggest, but this only occurred in very heavy rain. I took it to my dealer and they advised that the leak was much more likely to be due to a failure of the sealant between the window as a whole and the side of the caravan. They removed the windows and resealed them (fortunately under warranty) and this has entirely solved the problem.
i just wonder if this is also the case with your issue.
Best of luck.
Cheers
Paul RT
