The kitchen tap in our 2005 Bailey Pageant has been leaky since we got it- but only when you turn it on.
I did a bit of research, bought one of those ceramic inserts, and fitted it no problem. I thought it had fixed the issue, but if you move the direction of the tap (for example to lift or lower the glass cover, then to put it back over the sink later) the next time you use it, it leaks (but then doesn't on subsequent uses). It's only a few ml, but still.
I've taken the tap apart again and nipped the holding nut a bit tighter, which has helped a bit with the volume of water leaking but it hasn't stopped it completely and I daren't tighten any further.
Have I missed a trick here (such as needing a spot of grease/oil/glue on the rubber seal or something like that)?
