Leaping Hangers!
Sep 1, 2006
26
I read this in a caravan mag and it works a treat...hope I explain it ok.
Most curtain poles now come with the seperate round curtain rings, the ones you slide onto the pole with a small metal ring screwed in the bottom.
You can buy them individually from DIY and hardware stores. Pop them on your rail in the wardrobe then hang the coat hangers through the metal ring.
Works really well.
Feb 18, 2008
310
Hi Hovis
A simple way that we have found to stop hangers jumping off the rail is to alternate the hooks. One hooked over the rail from the front then the next hooked over the rail from the back etc etc. It really does work.
JohnM
Jun 16, 2010
99
8
18,585
hi buy 2inch pipe lagging the silver light stuff put your cloths on hanger hang them in wordrobe split lagging down middle and lay it over the hangers ends job done . tom
