Levelling Up?
Apr 1, 2012
28
Hello,
My caravan is on my drive, which has a slight slope.
I was under the impression that if I placed blocks under the two corner steadies, that would help level the van out. No matter how much or little I put under the feet it doesn't make any difference.
What am I doing wrong?
It's not that noticeable when you're in the caravan, but I think I've read somewhere that it's not good for the caravans frame as it puts it under stress. Is this correct?
Cheers
Dave
2,400
Hi Dave
Fore and aft levelling is done by using the jockey wheel. If you want to raise the nose of the caravan you should wind the jockey wheel down and vice versa. On a steeper gradient you can place blocks under the jockey before unhitching the caravan from your vehicle so that in spite of the steep slope the jockey will wind down enought to level the caravan. Chock the wheels before unhitching.
When the caravan is level wind down the corner steadies, never try to level the caravan by using the steadies as jacks.
If the corner steadies don't reach ground level then you make up the difference by using blocks.
Side to side levelling is done by using levelling ramps under the caravan wheel(s).
936
Never use the corner steadies to level the caravan, they are exactly what they are called "STEADIES"
Levelling should be done with ramps or planks of wood under the wheels for side to side level, and jockey wheel for front to back .
Only when level should the steadies be lowered.
Oct 30, 2009
1,542
hi Dave,
the information given by Parksy and Damian is absolutely correct and you should take note of it,
it may well serve you. to remember this is how you level the van on a site that is not level, so carry a few different thickness's of chocks with you as well as one of the leveling ramps for side to side leveling.
By the way I have noticed that you never seem to reply after asking a question ?? apart form this being common courtesy, it makes it difficult to know if any of the answers that have been given were usefull.
colin
2,400
colin-yorkshire said:
........By the way I have noticed that you never seem to reply after asking a question ?? apart form this being common courtesy, it makes it difficult to know if any of the answers that have been given were usefull.
colin
He hasn't replied yet to the answers he was given when he posted exactly the same thing word for word here either Colin
Apr 1, 2012
28
I'm sorry if i've caused offence to you Colin.
I really do appreciate everyones help, especially from Parksy, who has replied to every question I've had.
I do copy & paste on the other forum to gather up as much information as possable.
I am slowly learning more & more about my caravan & I am very greatful for all your help
Cheers
2,400
You're welcome Millar
The consensus from our friends on Caravan Talk and on this forum is that it's vitally important never to use the corner steadies to lift up or level your caravan, they are only lowered when you have achieved a level floor and the blocks are used to allow the steadies to rest on a solid surface.
I often use blocks under the corner steadies even on level ground where thereis room for them because the load is spread and there is less likelihood of damage to a damp grass surface.
4,984
Hi Parksy
I have been amazed at the number of seasonals on site in Snowdonia who have no jockey wheel at all!!
In it's place is a pice of scaffold tube , not touching the ground but holding a sat dish! all the weight is taken on the steadies. Lemmings comes to mind.
Apr 1, 2012
28
I have now removed the blocks of wood under the steadies, & lowered the jockey wheel. The van is still on a bit of a slope, but I can live with that!! Thanks again.
Dustydog said:
"I have been amazed at the number of seasonals on site in Snowdonia who have no jockey wheel at all!!
In it's place is a pice of scaffold tube , not touching the ground but holding a sat dish! all the weight is taken on the steadies. Lemmings comes to mind."
This is an old chestnut that comes up often
The Alko reply was that the steadies will more than take the load and most of the weight is on the wheels so you don't need to have the JW down
You can of course leave it down or up to suite your preference
This is a reply from Swift courtesy of CaravanTalk
We contacted Swift Group Technical and asked the very same question to get a difinitive answer.
The wheels take the whole of the weight of the caravan, the steadies remove the fulcrum action around the centre mounted wheeels, each steadie is rated at 500Kg and is more than capable of supporting the additional weight imposed on the outer parts of the floor by the occupier.
The Alko chassis hitch has a maximum static load of 100Kg, which is the maximum load that can be applied to thejockey wheel.
As to whether it should be left up or down, the recommendation is once you have your caravan level and steadies down, you should unwind the jockey wheel half a turn to remove the load, however ther is nothing wrong in removing it completely if you so wish.
GPS
In addition as the caravan settles on soft ground the chassis and steadies will flex to accommodate this, the force appled to the jockey wheel is a vertical load and will put additional stress on the extremeties of the chassis.
Moderators Edit:
Please do not try to pre-edit text using Microsoft Word or similar before submitting forum posts.
Notepad is ok to use because it does not contain hidden coding or if you want a spell check you should select Preview before submitting the post.
Oct 30, 2009
1,542
hi, no offence taken my friend , it was just a comment from a old hand
sometimes questions are asked, and in an attempt to answer them, a reply can involve a certain ammout of guesswork and some research has to be undertaken.
a reply would be useful as this then puts the answer into the right context. and of course knowing that the answer was benificial to the questioner.
feedback is Also useful for anyone reading the posts that may have a similar problem knowing wether an answer solved the problem or helped may give a starting point without them having to ask the same question later on.
without a reply to the answers the topic is dead in the water as no conclusions can be drawn as to what the original problem was if you know what I mean.
as you get better at understanding about our hobby and gain more experience over time it is nice to be able to help others, it is one of the best things about forums and makes the time spent at the keyboard wothwhile
GPS
Moderators Edit:
I didn't use Word
I just copied the quoted Swift information and pasted it
I used "quote" from Dustydogs piece but it left out what you have kindly inserted at the beginning so I added it after copying and pasting to make sense of my "old chestnut comment"
Its happened a few times that quoted pieces have not been quoted
I have now used quote again here so we will see if its done it this time ----or not
Seems OK this time
Sorry if I unwittingly caused aproblem
Here is a pic
Discover the jockey wheels !!!
chenzhen
BANNED
May 19, 2016
99
"The word vintage, used to describe dresses and clothing, is a broad term that is generally used to refer to clothing that originates from a past era. In general, clothing that dates earlier than the 1920s, is considered to be antique. Whereas clothing and dresses that have emerged after the 1920s, up to the 1980s and 90s, is considered to be vintage. Retro, or vintage style, usually refers to clothing that is an imitation of the style of a previous era.
A range of vintage style clothing that is hugely popular today, are the fifties dresses. The enduring popularity of these dresses, might be because that was the time women's clothing made significant strides, as it was after the second World War and many restrictions had been lifted and designers had more freedom and materials available to create beautiful women's fashion ranges.
Some of the popular dress styles that have enjoyed a timeless appeal have included the Ophelia dress, floral tea dresses, Audrey Hepburn style dresses, the figure hugging Lindy Bop dresses and dresses made famous by Grace Kelly and many classic Hollywood stars. Even today, young women are choosing vintage style dresses for their special occasions such as a ball, prom night, and other formal parties, because they have a definite charm and elegance and have been designed to enhance a woman's shape and beauty."
fake oakleys
michael kors uk
cheap ray bans
rolex watches for sale
nike free flyknit 5.0
ugg boots
coach outlet online
yeezy boost 350 white
michael kors bags
air max 90 white
ralph lauren outlet
louis vuitton bags
converse sale
coach factory outlet
adidas shoes
nike free flyknit 3.0
burberry outlet
nike air force
cheap ray-ban sunglasses outlet
tory burch shoes
nike tn pas cher
chaussure louboutin
adidas nmd runner
louis vuitton handbags
skechers outlet
oakley sunglasses cheap
cheap jordan shoes
ray bans
adidas nmd black
reebok classic
adidas trainers
vans store
nike cortez white
pandora charms
air max 90
adidas shoes
fitflops shoes
timberland uk
pandora charms uk
armani exchange
burberry bags
under armour
louis vuitton outlet stores
oakley sunglasses wholesale
pandora jewelry outlet
cheap basketball shoes
ferragamo
ralph lauren
pandora rings
toms outlet
michael kors outlet online
prada sunglasses wholesale
cheap ray bans
www.coachfactory.com
cheap air jordans
michael kors handbags
valentino
michael kors outlet clearance
michael kors outlet
ugg boots
ralph lauren
ghd
mizuno running shoes
nike air force black
cheap jordans
nike free run flyknit
cheap ray bans
sac longchamp
kate spade outlet
cheap ray ban outlet
ray bans
true religion jeans
babyliss hair dryer
michael kors bags
true religion outlet
reebok outlet store
ray bans
nike trainers
polo outlet
fitflops
adidas superstars
true religion outlet store
kate spade uk
discount nike air max
ray ban sunglasses outlet
jordan pas cher
levis 511
nike huarache
omega speedmaster
christian louboutin uk
michael kors outlet store
tiffany jewelry outlet
polo ralph lauren men
adidas supercolor pink
rolex replica watches
ray ban outlet store online
cheap nike air max
coach outlet store online clearances
tory burch flats
hollister hoodies
nike cortez shoes
louis vuitton outlet online
hollister hoodies
pandora jewelry
louboutin outlet
coach factory outlet online
adidas pure boost black
designer handbags wholesale
yeezy boost 750
true religion
kate spade outlet online
tiffany uk
lebron james shoes 12
red bottoms outlet online
cheap jordan shoes
jordans
gucci borse
gucci handbags outlet
ray ban sunglasses sale
lacoste shoes
bottega veneta shoes
michale kors uk
ray ban sunglasses discount
louis vuitton uk
cheap ray ban sunglasses
longchamp outlet
micahel kors
adidas superstar white
air max
cheap nfl jerseys
burberry outlet
christian louboutin outlet
hollister clothing store
oakley sunglasses outlet
ralph lauren
nike blazer
michael kors canada
birkenstock sale
cheap ray bans
white converse
louboutin pas cher
jimmy choo
ed hardy uk
bottega veneta sale
north face outlet
nike air max 95
burberry sale
abercrombie and fitch outlet
hollister kids
louis vuitton purse
supra outlet
nike huarache black
nmd adidas
asics running shoes
lacoste polo shirts
jordan shoes
michael kors canada
abercrombie & fitch
coach outlet online
tiffany jewelry
burberry outlet canada
ray ban sunglass,ray ban sunglasses,ray ban outlet,cheap ray bans,cheap ray ban sunglasses,cheap ray bans,ray bans
ralph lauren outlet online
canada goose outlet
mlb jerseys wholesale
vans outlet store
birkenstock sale
coach purses on sale
ferragamo outlet
valentino bags
rolex submariner
mont blanc outlet
hollister co
nike air force
the north face outlet
armani outlet
tiffany and co outlet
michael kors handbgas
cheap oakleys
north face jackets
dior sunglasses 2016
coach outlet online
north face uk
kate spade bags
polo ralph lauren outlet
ray ban outlet online
adidas nmd uk
ghd hair dryer
jordan shoes
hollister uk
michael kors uk
buy red bottoms
nike roshe run
kate spade outlet
toms shoes
cheap oakleys
louis vuitton factory outlet
polo ralph lauren outlet online
puma outlet
true religion uk
chi flat iron
fitflops sale clearance
true religion jeans outlet
michael kors outlet canada
michael kors outlet
oakley sunglasses
instyler max
true religion jeans
fitflops
fitflops shoes
polo ralph lauren
pandora sale
michael kors outlet stores
hermes outlet
cheap oakley sunglasses
nhl jerseys wholesale
toms outlet
longchamp uk
timberland shoes
asics gel kayano
michael kors outlet
ed hardy
polo ralph lauren
versace sunglasses wholesale
louis vuitton borse
kate spade handbags
new balance shoes
versace sunglasses
birkenstock outlet
oakley sunglasses,oakley sunglass,cheap oakley sunglasses,oakley sunglasses cheap,oakley sunglasses outlet,oakley store,oakley outlet,oakley outlet store,oakley sunglasses sale,oakley sunglasses discount
michael kors bags
birkenstocks
nike air max 90
timberland boots for men
kobe bryant shoes
adidas shoes
birkenstock shoes
christian louboutin shoes
under armour outlet store
rolex daytona
michael kors outlet
abercrombie outlet
birkenstock uk
cartier
omega
polo ralph lauren
true religion sale
burberry outlet stores
nike shoes for cheap
nike store uk
sac longchamp pliage
nike force 1
ecco outlet
coach outlet online
louboutin shoes
canada goose jackets
nike free runs
reebok
converse outlet
coach outlet online
stephen curry basketball shoes
hollister kids
jimmy choo outlet store
nike air max 90
hermes belt
louboutin shoes
supra store
stan smith adidas
toms outlet
rolex watches uk
wholesale nike shoes
gucci outlet online
yeezy boost 350
nike free 5.0
cheap nfl jerseys
reebok shoes
coach outlet online
coach outlet store
tiffany and co jewelry
timberland shoes
ray ban outlet
timberland boots on sale
cartier love ring
white converse
louis vuitton purse
air max 90
ralph lauren pas cher
air jordan shoes
prada handbags
michael kors canada
holliste sale
adidas gazelle
nike flyknit racer
oakley sunglasses uk
yeezy boost 350 balck
lebron james shoes 2016
ralph lauren outlet
nike running shoes
kobe 11
nba jerseys wholesale
coach outlet store
michael kors handbags outlet
hollister clothing
louis vuitton pas cher
ralph lauren sale clearance
cheap oakley sunglasses outlet
"One of the most popular, but simple fifties dresses, is the petticoat. This was designed to be flattering to a lady's shape and also, to enhance the dress she was wearing over it. Petticoats made of silk and woollen materials were initially introduced for women to wear under the main dress, as they provided warmth and would enhance women's busts. The classic petticoat then became shorter and lacy petticoats became the fashion, as they delicately accentuated the dresses that were worn over them, such as the Ophelia dress.
Vintage style dresses UK are available in a wide variety of sizes from vintage clothing shops, textile fairs, auctions, flea markets, estate sales, antique markets, garage sales and collectable fairs. However, there is always the risk with buying genuine vintage clothing, that the sizes may not match current clothing sizes. But there are a number of special boutiques online, who specialise in designing and creating vintage clothing to order. They can take your specific measurements and produce an outfit that will be tailor made and fit you perfectly"
,dhl,h
