Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
We’re currently investigating an issue related to the forum theme and styling that is impacting page layout and visual formatting. The problem has been identified, and we are actively working on a resolution. There is no impact to user data or functionality, this is strictly a front-end display issue. We’ll post an update once the fix has been deployed. Thanks for your patience while we get this sorted.
When on site and unhitched from car, before disengaging the mover, use a levelling ramp to level left to right. Once happy with this, apply hand brake and level front to rear using jockey wheel. Again once happy, lower corner steadies - job done.
This is how I would do it but I am always willing to accept correction....
HI TAPESTRY,i have a twin axle,i find easier to to go forward onto the leveller with the mover,i put a wedge behind the wheel,you will find it easier this way ,then follow what chris said.hope this helps you. ALL THE BEST ALAN P/T
"What if you have a alko wheel lock. How do you get them aligned."
In essence drive up ramp to find hight require; remember this position on ramp.
Come off ramp and find wheel position where lock will fit, lay small marker stick or coin by tyre.
Back off, then place ramp where the hight is right against the marker and drive up ramp.
Sounds a hassle but in reality with a good team its done in no time and usually whilst still connected to the towcar so as not to use any battery power.[non EHU]
