locating drain plug for carver water heater on 1980's Pirouette
Laureen, it is on the outside of the van, at the bottom left of the cascade cowling.
It is a large plastic plug with either a single slot in the end or a cross shaped slot.
Thank you so much I would never have found that on my own, it is draining as I type. I did open taps and run them dry at the end of last trip, should I do this again? No sign of any wet inside the van, fingers crossed I got away with it during last really cold spell. Thank you again.
There should also be an air bleed screw in the top left corner of the cowl to make it empty a little faster too.
Look up ARC systems. Gary the owner and who posts on this site has a wide selection of instruction manuals for many of the Carver products
