Lunar EB Awning size help
Ok my ground to ground on the Lunar is 985 cm. I have been offered two awnings that are cheap to replace my storm ripped awning. The two sizes are 975 cm and 1050 cm. Will I get away with the 975 cm one (2" either side).... Thanks for the help, its a great caravan by the way and we sleep 3 kids and two adults in it easilly :).... The two awnings are £200 each thats why I'm interested in them and both 2 years old
936
I think you could just about get away with the shorter one on levelground, but may struggle on sloping pitches.
The longer one would be ok on slopes, but coul dbe a problemon level .
Dosent help much I know,but thats the way it looks
Nov 1, 2005
1,001
you could buy the larger awning ang spend another 50-60 quid getting it reduced to fit properly.if its a decent awning it would be easily worth it.
Aug 4, 2004
4,343
Go for the 1050 as then sloping pitches are not a problem. We had the CS with the 975 and on a few occasions discovered it was just that bit too short.
