Marker lights? replace or remove
Apr 19, 2010
18
One of my front marker lights is damaged, I was wondering if there is a legal requirement to have them (in which case i'll need to replace them) or can they be safely removed?
What are they designed for anyway?
808
lutzschelisch.wix.com
You refer to front marker lights so I presume you mean the white position lights facing forward. These are a legal requirement if the caravan extends more than 400mm beyond the outermost illuminated part of the towcar.
Nov 29, 2007
667
If the caravan is more than 1.6 m wide and built after 01/10/85 then front position lamps are a legal requirement under UK C&U regulations
40
On a related matter, what is the legal requirement for side marker lights - usually amber - fitted to continental 'vans ?
These seem to use the bodywork as the return connection and over the years these connection become unreliable. I guess the anser is to re-wire with two 'proper' wires, but this seems a lot of fuss for something which may be unnecessary anyway - amber reflectors would seem to do much the same job.
