These seem to be advertised a lot in recent publications. Have you any experience of using this dish and what is it like to fit?
Please help.
Al
Please help.
Al
http://www.maxview.co.uk/acatalog/OMNISAT_SEMITRONIC.htmlI have the Maxview Semitronic which is the same as the crank up in dish size but has a motor to raise the dish
I prefer it because all the stresses are taken on a pole that is fastened to a wall inside the caravan such as a wardrobe etc and so the thin aluminium of the van roof is less strained
It is true that you have to think about pitching and avoid trees etc but you do have to do that with the portable tripod set up and on the van roof it can clear obstacles
I carry a tripod and dish but so far in 2 years plus have not needed to use it yet
Fitting the Semitronic is quite easy and the instructions are very well written and easy to follow
http://www.maxview.co.uk/acatalog/OMNISAT_PORTABLE.htmlI have the Maxview Semitronic which is the same as the crank up in dish size but has a motor to raise the dish
http://www.invacom.com/documents/DBSLNBCoverSheet.pdfHi B
Which one/type do you use
We have had to put the dish down or guy it in high winds
Last time away at Blackpool it was the night of very high wind mid March when attempts to refloat Riverdance were abandonned
I had the dish down for prudence until HRH needed to watch a football match so it had to brave the elements!!
I've seen several roof mounted dishes guyed against the wind
The tuning bars are all the way across on signal quality and almost to the end on signal strength
Its much better than the house mini dish which is accessible and kept tuned for optimum readings
Maxview are very good at sending spares quickly
I don't know if the crank up uses the same plastic clamp screw/collar but I have cracked 2 using the plastic spanner so now its just tightened by hand and an extra aerial clamp is used on the pole as well
